Ayuda! problemas ECU & BCM
  • Ayuda! problemas ECU & BCM
    Instalando la alarma en mi Corsa C y pasando cables por el mazo de la puerta al interior me he cargado algo.
    Sintomas:
    1) Se funde un fusible de la BCM cada vez que acciono el cierre.
    2) El OpCom me registra la siguiente imagen en el apartado de la ECM:
    3) Al arrancar el coche se inicia revolucionado (1300-1400rpm) y el acelerador no va (lógico viendo la anterior imagen)
    Valores de la ECM en tiempo real pillados con el OpCom:
    Ignition Status, On 12V
    Battery Voltage, 13.5 V
    Main Relay, Active
    Spill Valve Relay, Inactive
    Accelerator Position Sensor Signal, 5.1 %
    APP Sensor 1 (Accelerator Pedal Position), 0.98 V
    APP Sensor 2 (Accelerator Pedal Position), 4.98 V
    APP at Idle Position (Accelerator Pedal Position), Inactive
    Simulated Full Load Switch, Active
    Mass Air Flow Sensor, 4.98 V
    Mass Air Flow Sensor, 800.0 kg/h
    Boost Pressure, 2.31 V
    Boost Pressure, 100 kPa
    Boost Pressure Command, 0 kPa
    Barometric Pressure, 4.82 V
    Barometric Pressure, 101 kPa
    Intake Air Temperature, 4.98 V
    Intake Air Temperature, 30 °C
    Coolant Temperature, 2.57 V
    Coolant Temperature, 48 °C
    Fuel Temperature, 35 °C
    Brake Switch 1, Inactive
    Brake Switch 2, Inactive
    Clutch Switch, Inactive
    Oil Pressure, Underpressure
    A/C Information Switch (Air Conditioning), Inactive
    A/C Pressure (Air Conditioning), 4.98 V
    A/C Pressure (Air Conditioning), 800 kPa
    A/C Coding (Air Conditioning), A/C Detected
    Actual Injection Start, 0 °CA
    Injection Quantity, 251.0 mg/strk
    Pulse Ratio Boost Pressure Solenoid Valve, 0.0 %
    EGR Pulse Ratio (Exhaust Gas Recirculation), 0.0 %
    Pump Speed, 0 RPM
    Engine Speed, 0 RPM
    Desired Idle Speed, 0 RPM
    Glow Time Relay, Inactive
    A/C Cutoff Mode (Air Conditioning), System OK
    A/C Relay (Air Conditioning), Inactive
    Vehicle Speed Pulse, Not Received
    Vehicle Speed, 0 km/h
    Telltale (Check Light), On
    Glow Time Telltale, Off 12V
    Diagnosis Glow Time Relay, Inactive
    Outside Temperature, 14.8 °C
    Fan Relay 1, Inactive
    Fan Relay 2, Inactive
    Fan Relay 3, Inactive
    Immobiliser Function Programmed, Yes
    Security Wait Time, Inactive
    BCM: Vehicle-ID is programmed (Body Control Module), Yes
    Instrument: Vehicle-ID is programmed, Yes
    BCM: Status of Vehicle-ID (Body Control Module),Okay
    Instrument: Status of Vehicle-ID, Okay
    He mirado esquemas, y los valores que fallan son todos los que pasan por "el mazo de cables de la carroceria delantera" que no se exactamente donde están. Mirar el esquema:
    Si alguien pudiera pasarme un log de los suyos con la llave dada pero sin arrancar.
    Un saludo!
