Pues depués de mucho tiempo , he encontrado una resistencia variable k se conecta a la dirección eléctrica para poder regularla "comodamente" ....
todos sabemos k la dirección de nuestros corsas "C" es eléctrica.. y según la velocidad y rpm esta se endurece.... pues esos valores se pueden modificar manualmente con esto:
Vauxhall Corsa B or C column Controller
The controller works by simulating engine and vehicle speed signals which are generated by the controller using two independent oscillator signals. The vehicle speed oscillator rate is controlled by the potentiometer which adjusts the column’s assistance.
The device is equipped with a new connector ready to fit to the steering ECU. The only connections required are power connections making electrical installations easier. It also includes Velcro strips for mounting the controller near the ECU.
The potentiometer shaft can be reduced in length as desired for a flush finish when the pot control is mounted behind dash panels etc. The potentiometer connections are all insulated not having any exposed conductor that could cause operational failure.
An under dash mount bracket for fitting of the potentiometer can be supplied on request if a convenient position on the dash is unavailable. Simply request at the point of payment using message to seller.
As in previously sold units the components are populated onto professionally engineered FR4 spec purpose made PCBs. The device has an excellent operational record and been used in many kit car and motor sport applications. This product was also the pioneer in making end-user cost of these devices more realistic.
We have been selling these devices for some considerable time now with hundreds of successful installations with many happy customers. We have engineered this device to last with respect to the harsh automotive application.
Always happy to answer any questions on the device, its application or if you prefer to contact us on engineering a Corsa B/C column controller device to your specific requirements please ask.
Precio: unos 25 € + envío
