¿Qué motor tenemos?
  • 1.0 S OHV 8v(45cv): Eleektro, Gabi
    1.0 12v(54cv)ade XIII, Mutilo; Davidjk7,Wrome, Elenavix, BuLe_WRC
    1.0 12v(58cv): cannabis_33
    1.0 16v Twinport(60cv):
    1.2 S 8v(55cv):arrasss, locochery, Peseta_85, cuatrolatas
    1.2S 8v(52cv):euskal_opel
    1.2 8v(45cv):Swing87, ociomas
    1.2 16v(65cv):Rotciv, fgp, Manza
    1.2 16v(75cv): korsa16, inssen, txoni, maloplas,f_r_a_n100,corsa_black, Corsario_Azul
    1.2 16v Twinport(80cv): moni1983, PepiRCiNG, soilu,OPEL77,Ivan1988,Ferry, LLVR, Ripnosis
    1.3 8v(70cv): Exodia, corsatf
    1.3 CDTI(70cv): fer630, gasolino23, Dark, turbillo
    1.3 CDTI(90cv): Juja, Spino, Triskel
    1.4 8v(60cv)anuvid,Autocorso,javito_86, Gilber, Jesusmar
    1.4 SI 8v Multipunto(C14SE / 82cv):Corsapucela, Alka, Hectorjl
    1.4 16v(90cv): Maxicorsa Luisja, Juanchomoruno2x1,ADNGMA, AMtuner,lag5147, alynika
    1.4 16v Twinport(90cv): Scroller83, CorsaTux, arrasss, will , Pinindres, djferm
    1.5 D(50cv):acarmelo
    1.5 TD(67cv):Pender
    1.6 8v(95cv): Potamito
    1.6 8v(100cv): JOSETI, SCHWX, Dano
    1.6 16v(106cv):
    1.6 16v(192cv):
    1.7 D(60cv): El_Jairo, CorsiGirl, JaViToRiC,eLmEtXeRo.
    1.7 DI(65cv):arualyjuanto, Kritxa1983
    1.7 DTI(75cv): swotu, Corsa_Robles
    1.7 CDTI(100cv): Racingleon, Navser, 100cv, SiFerVi, Nuka,corselius, el_javi,Carin, Gabi, rifo_madrid_21
    1.7 CDTi(125cv): XploD
    1.8 MPFI(107cv): StyleXtream
    1.8 16v(125cv): spidii, sergijam, Exodia, unlafor
    Corsa D 1.4 gasolina
      1.5 TD(67cv):Pender
      1.6 16v(106cv):
      1.6 16v(192cv): Chemary
      NOTA INFORMATIVA, DARLE AL BOTON CITAR del ultimo post,AÑADIS VUESTRO NOMBRE DONDE CORREPONDA, Y LUEGO BORRAIS AL PRINCIPIO Y AL FINAL DEL TEXTO, TODO LO QUE ESTA ENTRE [ ] QUE CONTENGA LA PALABRA QUOTE. Y NO BORREIS ESTA NOTA ni ningun nombre.
        1.5 TD(67cv):Pender
        1.6 16v(106cv):
        1.7 CDTI(100cv): Racingleon, Navser, 100cv, SiFerVi, Nuka,corselius, el_javi,Carin, Gabi, rifo_madrid_21, Rebote
          1.5 TD(67cv):Pender
          1.6 16v(106cv):
          1.7 DTI(75cv): swotu, Corsa_Robles, Plamet
            1.5 TD(67cv):Pender
            1.6 16v(106cv):
            1.8 MPFI(107cv): StyleXtream, lakitu78
              1.2 16v Twinport(80cv): moni1983, PepiRCiNG, soilu,OPEL77,Ivan1988,Ferry, LLVR, Ripnosis, castronight
              1.5 TD(67cv):Pender
              1.6 16v(106cv):
              UNA VEZ ME DIJERON QUE MI CORSA COGIO 7200 RPM
              • Hola , solo una pequeñisima aclaracion los motores 1.0 SOLO tienen 12V,pues llevan tres cilintro.
                • Buenas.
                  Justo encima de ese, hay uno de 8 valvulas no?, asi que no todos son de 12 valvulas.
                  Es eso a lo que te referias?
                  • Originalmente publicado por corsa
                    No se si es una pregunta o una afirmacion. Algo parecido ya se comento en este mismo tema, unos mensages mas atras. El B y C 1.0, efectivamente, son de 3 cilindros, 12V. El A es un 1.0 de 4 cilindros, 8 valvulas.
                    • Ahora tengo yo una duda...qué diferencia hay entre el 1.4 16 V (90 CV) y el 1.4 16 V (90 CV) Twinport???????
                        1.5 TD(67cv):Pender
                        1.6 16v(106cv):
                        1.7 DTI(90cv):wif-abp
                        Corsi 1.7 DTI Ellegance
                        ...The world is yours...
                        • Originalmente publicado por alynika
                          De esto tambien se habló en otro tema:
                          Originalmente publicado por GeRsIo
                          El twinport es... un sistema de admisión variable en función de la carga del acelerador y el regimen de giro del motor.
                          Supuestamente tiene que consumir menos, no sé si sera verdad.
                            1.4 16v Twinport(90cv): Scroller83, CorsaTux, arrasss, will , Pinindres, djferm, Dize
                            1.5 TD(67cv):Pender
                            1.6 16v(106cv):
                            http://www.comunidadcorsa.es/modules...911&highlight=
                            • Originalmente publicado por Mutilo
                              Ok, entendido, el mío no es Twinport
                                1.5 TD(67cv):Pender,joserubio
                                1.6 16v(106cv):
